So I have a pretty old Toshiba laptop A75-S125 which came with a Pentium 4 @ 3.2ghz/HT 533mhz bus, 512mb 266mhz memory, and Radeon IGP 9000, and 40gig 5400 rpm hard drive. It ran on XP. It ran fast and it never lagged. I always clean the insides with compressed air and I even removed the heat sink to re apply new thermal arctic 7 compound. So actually 2 year ago it started to really slow down and the the fans would rev and stay at max. I ran HD tune to check to see if my hard drive was dying but I got 45MB/s average speed which was the same result when I first bought my laptop in 2006. I then formatted and did a clean install of windows. Still it would rev up and was really slow. I even replaced the CPU with a celeron and still the same problem. The funny part is that it would boot up really fast but once i get access to the desktop running any program would be slow as a snail. So the I decided to buy a new 120 gig hard drive and another gig of memory and did fresh install of windows xp. Still the same problem. I checked the heat sinks to make sure it was firmly placed over the CPU and it was fine. I left my laptop in the closet for a while and decided to finally ask for help since i have some free time. I really don't know why it is so slow. Could it have bad capacitors, mosfets, or even a faulty thermal sensor? Could such things be fixed. I really like my laptop and I have a lot free time so I am willing to fix it even if it seems not worth it to other people.
Thanks
Thanks
