So my laptop has a physical separate left and right mouse buttons and they don't work, I took the laptop apart and found out they are attached to the keyboard, then i turned it on and physically pressed them and still nothing so i was wondering if you got any tips to fix them? the mouse pad works just left and right clicks.
Maybe a re-flow in in order? just under it?
Also i am having trouble reattaching the keyboard ribbon there is like 2 inch gap that i have to get two chopsticks and reattach them really annoying but i can't get this one last connector to go in.
