Laptop replacement LCD help
The same laptop model might come with different screens sometimes made by different manufacturers.
If your laptop screens resolutions is 1920 x 1080 or below usually it has a 30-pin connector.
I suggest you remove the screen and look at the model number / part number and also the type of connection.
