laptop screen dead on from adopter but it turn on battery
abjalson
hi, I have a Dell Inspiron 15 5521 laptop, after replacement of cracked screen laptop is dead on from adopter but it works fine on battery, power adapter is fine and new, help me out
Hi,
When you replaced the screen there might be a cable that had been disconnected or got loose. I would retrace the steps you did with your PC and make sure everything is seated properly. If it's not working fine with just the AC adapter and the battery is removed that means it could be the AC adapter port or cable that connects it to the motherboard. Lastly, try another AC adapter that has the same voltage and see if it will work.
