Question Laptop screen goes crazy after 30 minutes of use ?
Jan 18, 2022
View: https://imgur.com/a/J0siFeJ
Laptop: Ativbook 2
CPU: i3 3110M
The freezing+artifacting happens regardless of the load. Either running at full throttle or just browsing the web with a couple of tabs open, after 20-30 minutes the artifacting begins and the laptop completely locks up.
Temps aren't particularly high for an old laptop(mid 50s), but I cleaned the whole thing and changed the thermal paste just to be sure but nothing changed.
Don't know if this information helps, but I used to abuse the hell out of it before I bought a PC. It ran the games it could for hours with temps hitting the high 90s even with a fan pointed directly at it. The weird thing is that those issues only showed up a few months after I stopped using it under those extreme circunstances.
The black dot is just a bunch of dead pixels that showed up a few years ago so please ignore it.
Thanks in advance for your time.
