Laptop Screen Problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
My laptop's screen has switched to a larger view that doesn't use the whole
screen, there's about and inch and a half of black screen on both sides of
the window, and i can't figure out how to get it back to normal. Please Help
Megan
right click an open spot on the desktop
properties
settings
change the screen resolution back to what it used to be
peterk
Never trust a computer you can't throw out the window. - Steve Wozniak
"megspurplewall" <megspurplewall@discussions.microsoft.com> wrote in message
news:2CDB6199-9202-4809-AB5D-A936B4063F5B@microsoft.com...
> whole
> Help
> Megan
If you have the Intel Mobile Graphics adapter, click on the graphics
icon in the system tray, and look for the 'Graphics Properties'
option. It should be in the Graphic Options if you have a system like
mine. Once there, click on the 'Full Screen (No Border)' box.
Megan
right click on your desktop anywere that has no shortcut key and a menus
will open. left click "properties" then click left click settings then you
can change your screen size or resolution. you may have to try a couple
difference setting to get it back to what it was.
TJ
> whole
> Help
> Megan
