Laptop shuts off randomly on battery power
geo141
41
I have an MSI GE60 0ND laptop running Windows 7. When using battery power the laptop shuts off randomly and I have to plug the AC adapter back in to turn it on, then the battery shows that it is at 0% charge even if it was fully charged before it shut off. There is a message on the battery icon saying that there is a problem with my battery and that it may need to be replaced. My question is, can I trust this message, should I replace the battery? Is it possible that something else is wrong with the laptop?
usually yes, the battery can die and system can enter in the state you describe
in very few cases the laptop is wrong and gives a false positive but is cheaper to buy a battery and not a laptop
is it under warranty?
How long have you had the laptop? If it's more than a couple years I would go ahead and purchase a new battery. My old Compaq Presario laptop went thru about 1 battery every year and a half. Turned out half of my problem was a dying power brick and probably didn't need to replace my battery as often as I did. Lessons learned.
I just bought the laptop used, I believe it is from around 2013 though. Are you saying I might need to replace my AC adapter too?
It's not under warranty, but I am okay with buying a replacement battery. I just want to be sure I am fixing the right component.
here 3 things can fail, the os, the battery and the mainboard
if it is the os, that i haven't seen happen with a batter, the other is the batter, after 32 or 3 years most die, just simply die
the other is the mainboard, if it is that, it will end up as a desktop pc and not a laptop
lets hope it is the battery or better start saving for a new laptop
You do not need a new A/C adapter unless the battery has trouble charging or if the laptop cannot run off the adapter alone.
When my laptop's GPU fried I got a replacement motherboard. I originally thought the charging circuit on the board was bad as well and that's the reason I thought for the batteries not working properly. And that I couldn't run the laptop on the A/C adapter alone. When I replaced the board the adapter problem wasn't fixed. In fact I noticed that the battery wouldn't charge at all and literally the next day my adapter died. Bought a new adapter and the laptop runs like it was new.
