laptop static noise
chuckd89
Commendable
Jan 9, 2017
I have a dell laptop that now has static sound coming from the speaker audio jack. It will go into the headphones if you plug them into the jack. It does not go up or down or away by adjusting the volume. I have tried the Audio troubleshooting, nothing came up. I have checked the device manager, update drivers, etc. That did not work. I have blown air into the jack and other areas of the computer to clear dust. I have unplugged the laptop from the power cord. None of this makes any difference in the static noise. It is a dell laptop running Windows 8
NOTE: It is quiet normal for heaphones plugged into a computer, when not playing any kind of sounds, to have a static like sound on them.
Here are some things to try.
1. Make sure that the wires for your headphones do not come into contact with other wires going in and out of the computer. Anything it touches that can have any kind of electrical current can cause noise in the headphones.
2. Try a different headphone jack, if you have more than one.
3. Try a different set of headphones and see if they have the same sound problem.
4. Plug the headphones into a different device and see if you get the same sound issues. If so, it may be within the speakers themselves.issue.
5. Connect the headphones through a USB connection (this...
5. Connect the headphones through a USB connection (this will require an adapter for standard plug heaphones) and see if the problem goes away. If so, it may be the headphone jack on the laptop that is the
6. Upgrade your headphones. All recorded audio has a degree of noise or static; how obvious it is to the listener depends on the quality of the media it’s recorded on, the playback technology and the listening device. Replacing your headphones with a noise-reducing or noise-canceling set could clear up the problem.
7. Worst case, if the problem happens with multiple headphones, you may need to replace the sound card.
