Laptop takes forever to shut down(and some other problems)
PetarV
118
My laptop: http://www.newegg.com/Product/Product.aspx?Item=N82E16834232848
I bought it recently and I'm experiencing some problems.Sometimes it takes forever to restart/turn off probably more than 10 minutes.Another problem is that when I turn on some games on the loading screen there are blinking red and blue dots.GTA V becomes black and white.NFS Rivals doesn't start sometimes and i have to turn it off and on again.Dark Souls III gives me A LOT of BlueScreens and crashes(only when I start the game).And finally when I try to turn on No Man's Sky it just crashes.This happens every time.
P.S. All the games are cracked.
Edit: I've just noticed it won't tun on either.It's stuck on the Welcome screen!
G
If you can get it to restart, try using Qihoo 360 - there are a lot of features that can not only get rid of viruses and malware, but tune-up and clean-up tools too.
What sort of antivirus do you have? Perhaps one of the cracks is infected. I lost my whole OS to a crack.
ESET NOD32 Antivirus.The torrents are from Zamunda and a lot of people have downloaded them.I honestly wouldn't expect a virus from zamunda when my antivirus is updated.
I'm not familiar with ESET NOD32 but according to google its quite good, Have you tried running a GPU and CPU temperature test?
Here is a download to one if you do not have one: http://openhardwaremonitor.org/
Also have you done any overclocking?
I haven't done any overclocking and I haven't had cooling problems at all (with my cooling pad).
Btw my laptop still hasn't turned off ;-; It's getting way over 10 minutes and I can't use Open Hardware Monitor.
I've noticed that my new laptop turns on way slower than it should(I'm not talking about when its stuck on Welcome screen).I have and i7 and I assumed than it would turn on faster than my old one with an i3 but its the other way around.My old one turns on for less than 20 sec and my new one 25-30 sec sometimes even slower.
Hmm.... that laptop certainly has the punch required to run those games. the only thing i can think of is hardware failure of some sort, so when the laptop comes back on try the heat test, if they are running anywhere hotter than 75 degrees then its to hot.
Nothing is with temperatures higher than 45.
My problem is that at the start of the games they crash or have blinking red and blue dots not that they crash when I'm playing them.When is finally manage to play them they don't crash.I have problems when launching games.
