Laptop Weird Fan Problem
Nov 12, 2018
Hello all,
I have a pavilion g6 1215et laptop. When I start laptop, fan starts and working normally, but when cpu temperature goes down, fan starts slowing with weird noises and stops. After it stops laptop starts beeping(single beeps) randomly. Laptop becomes very hot like 99 degrees and the fan somehow starts again. If temperatures keep high, fan works normally; but when it drops again fan stops and never start.
As a workaround, ie. when playing games, first I open the game then cpu temperature goes high and I put laptop sleep mode and open again, waking laptop from sleep triggers fan and it never stops as long as cpu temperature is above 60~C.
What should be the problem is? The beeping noise is very irritating, any help?
I replaced the fan today, it went for one hour then same behaviour started again. Is there a way to set minimum speed on fan?
