Laptop will not turn on unless battery is removed
PPPLSTWN
ASUS Aspire V3 Series laptop will not turn on unless battery is removed. When battery is installed after laptop is turned on, it turns off by itself. Just installed a new battery. Pls help!
PPPLSTWN
1shado1, you're right it's an Acer. Yes, it did the same with the old battery. I bought the battery from Amazon, it's not OEM.
1shado1
Try checking the metal contacts in the battery compartment. Do they all look normal/straight? Do the same for both batteries as well.
How old is the original battery? Did the malfunction prompt you to buy the new one, or did the problem just start after inserting the new battery?
