Ok so I’m pretty sure I messed up bad. I have a HP Envy 15t x360 aq200. After a bios update (just bought this laptop) I noticed some issues. I tried to roll the update back, or repudate it, by holding the Windows key + b then holding the power button.
The laptop turned on then off a few times then nothing happened. When I tried to power it back on, nothing happened.
Now when I try to power the laptop back on, all I get is a black screen, the fan starts briefly for a second, then stops. Power light stays on for a few, then turn off. Then it turns back on.
It’s stuck in this loop.
Windows key + b won’t even work anymore and doesn’t power the laptop on
Did I just “brick” this laptop?
It doesn’t have a removable battery if that matters at all.
Thank you for any help / advice
