Hi everyone.
I have a laptop that I sometimes connect to a large TV that has HDMI ports on it.
Lately though, I haven't been able to get what's displayed on this laptop to mirror to the TV with the HDMI ports. The TV used to be detected as a display, but no longer.
The hardware and connections seem okay; I think it's probably a software issue and not a hardware issue since I'm able to mirror the display when I connect a separate laptop to the TV via an HDMI cable.
Has anyone experienced and solved this problem before? If so, how did you fix it?
Thank you.
P.S. The laptop in question uses Windows 10 if that helps.
Thank you.
