hi, i know this thread is old, but for anyone suffering the same issues:
i had exactly the same problem and found an answer on an HP site, which solved my problem, it was a faulty battery driver
easy fix in 5min
http://h30434.www3.hp.com/t5/Notebook-Lockups-Freezes-Hangs/Laptop-battery-not-charging-but-laptop-works-with-power/td-p/1049529
First of all, shutdown the notebook, unplug the AC Adapter, remove the battery, and then hold down the Power button for a full minute.
Now, plug in the AC Adapter without the battery inserted, start the notebook, open windows Control Panel, open Device Manager, expand the entry for Batteries, right click on and the Microsoft ACPI Compliant Control Method Battery and select Uninstall - do not uninstall anything else here. When the uninstall is complete, shut the PC down, unplug the AC Adapter, re-insert the battery and then start the PC on just the battery. Windows will automatically reinstall the driver - leave Windows running for a few minutes. Shutdown the PC again. Now plug in the AC Adapter ( with the battery still inserted ) and start the notebook to see if this has helped the issue at all.
