Can anyone recommend a specific case upgrade for an IdeaCentre 5-14IOB6 Desktop motherboard - specifically one which is large enough to fit a GPU such as a Radeon RX 580 and a 550W power supply?
The factory motherboard I have is perfectly compatible with a Radeon RX 580 or GTX 1070 TI graphics card, but the default case it comes with is too small to house those GPUS or a larger 550W power supply, so I all I need is a larger motherboard-compatible case and I should be good to go.
