Archived from groups: comp.periphs.printers (More info?)
I have a HP 4M+ to do my normal B&W printing and can't fault the old beast,
but I now need to print onto paper heavier than the 120g or so that the HP
can handle without reporting a paper jam.
I need recomendations for a printer that has a fairly straight route for the
A4 paper to travel during the print process so that it can handle heavier
paper (about 180g) ie a top loader. The HP frequently won't even pick up
heavier paper and then it is almost guaranteed to jam somewhere in that
figure "S" route that it takes around the fuser.
A fairly small footprint is a secondry consideration along with price and A5
compatibility. It will be for home use use rather than office volumes.
Cheers,
Binky.
Cheers,
Binky.
