I've been with the same ISP for roughly a year now and hadn't had any issues until about 2-3 months ago when this problem first started.
Standard operation of my internet connection is pretty solid, it's only when I start to try online gaming that the issues begin to arise. 90% of the time, my connection will be fine, yet the other 10% (which is usually in some critical point of the game) my ping will skyrocket, I'll be locked in place for 5-6 seconds, and then it'll go back to normal.
During these times, I Alt+Ctrl+Del and go into task manager, and each time, the Networking tab and the tracker is off the charts...literally.
Troubleshooting I've done so far....
Called my ISP and they told me they could see a lot of interference on my connection. They sent out a tech, and he replaced the entire line from the phone pole to the demark, and from there to my modem.
(Didn't fix it)
Replaced my entire Modem
(Didn't fix it)
Replaced the ethernet cable
(Didn't fix it)
Updated all drivers, firmware, etc.
(You guessed it)
When I run a ping test to 8.8.8.8, everything comes back fine. Running Speed Test, everything is normal.
This affects both my Ethernet and WiFi connections, but in different ways. On WiFi (on my phone) certain messaging apps, like WhatsApp will hang for upwards of 10 minutes before sending or receiving anything, so I'm now forced to use my Data plan if having a conversation.
My WiFI is run on 5g, I use WiFi Analyzer to track the strength. On paper, and through programs used to monitor my online activity, everything should be fine...but it's not.
My ISP is basically just shrugging at me at this point and I have no idea how to fix it.
(Didn't fix it)
(Didn't fix it)
(Didn't fix it)
(You guessed it)
