Question LatencyMon Problem
Sep 28, 2023
hi guys! i recently upgraded my pc and ive been having some audio issues-- it's very crackly and cutting in and out constantly. I ran latencymon and im not sure now to fix it TT please help. I've updated my bios with flashback and I while I have wifi capabilities on my pc, i have it off and use ethernet
CONCLUSION
_________________________________________________________________________________________________________
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. Also one or more ISR routines that belong to a driver running in your system appear to be executing for too long. At least one detected problem appears to be network related. In case you are using a WLAN adapter, try disabling it to get better results. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:02:15 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-EEGN4LK
OS version: Windows 10, 10.0, version 2009, build: 19045 (x64)
Hardware: System Product Name, ASUS
BIOS: 3205
CPU: AuthenticAMD AMD Ryzen 5 5600X 6-Core Processor
Logical processors: 12
Processor groups: 1
Processor group size: 12
RAM: 16295 MB total
CPU SPEED
Reported CPU speed (WMI): 3701 MHz
Reported CPU speed (registry): 3693 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 309.20
Average measured interrupt to process latency (µs): 5.090179
Highest measured interrupt to DPC latency (µs): 306.70
Average measured interrupt to DPC latency (µs): 2.516929
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 1890.877335
Driver with highest ISR routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%): 0.006202
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.006874
ISR count (execution time <250 µs): 187553
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 1
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 2182.479014
Driver with highest DPC routine execution time: ndis.sys - Network Driver Interface Specification (NDIS), Microsoft Corporation
Highest reported total DPC routine time (%): 0.073925
Driver with highest DPC total execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in DPCs (%) 0.238432
DPC count (execution time <250 µs): 480612
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 50
DPC count (execution time 1000-2000 µs): 1
DPC count (execution time 2000-4000 µs): 14
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: svchost.exe
Total number of hard pagefaults 619
Hard pagefault count of hardest hit process: 439
Number of processes hit: 25
PER CPU DATA
CPU 0 Interrupt cycle time (s): 8.443702
CPU 0 ISR highest execution time (µs): 13.445437
CPU 0 ISR total execution time (s): 0.025746
CPU 0 ISR count: 32807
CPU 0 DPC highest execution time (µs): 2182.479014
CPU 0 DPC total execution time (s): 2.839145
CPU 0 DPC count: 360517
CPU 1 Interrupt cycle time (s): 2.259133
CPU 1 ISR highest execution time (µs): 1890.877335
CPU 1 ISR total execution time (s): 0.058787
CPU 1 ISR count: 95173
CPU 1 DPC highest execution time (µs): 135.185757
CPU 1 DPC total execution time (s): 0.949017
CPU 1 DPC count: 101134
CPU 2 Interrupt cycle time (s): 0.478599
CPU 2 ISR highest execution time (µs): 3.06580
CPU 2 ISR total execution time (s): 0.000525
CPU 2 ISR count: 554
CPU 2 DPC highest execution time (µs): 1184.801516
CPU 2 DPC total execution time (s): 0.015345
CPU 2 DPC count: 3025
CPU 3 Interrupt cycle time (s): 0.504775
CPU 3 ISR highest execution time (µs): 1.713241
CPU 3 ISR total execution time (s): 0.000061
CPU 3 ISR count: 58
CPU 3 DPC highest execution time (µs): 68.048741
CPU 3 DPC total execution time (s): 0.004964
CPU 3 DPC count: 1475
CPU 4 Interrupt cycle time (s): 0.435546
CPU 4 ISR highest execution time (µs): 1.172218
CPU 4 ISR total execution time (s): 0.000008
CPU 4 ISR count: 8
CPU 4 DPC highest execution time (µs): 23.233956
CPU 4 DPC total execution time (s): 0.001202
CPU 4 DPC count: 457
CPU 5 Interrupt cycle time (s): 0.427140
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 20.649066
CPU 5 DPC total execution time (s): 0.001636
CPU 5 DPC count: 862
CPU 6 Interrupt cycle time (s): 0.523567
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 42.039534
CPU 6 DPC total execution time (s): 0.004583
CPU 6 DPC count: 1526
CPU 7 Interrupt cycle time (s): 0.364505
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 23.915245
CPU 7 DPC total execution time (s): 0.000836
CPU 7 DPC count: 299
CPU 8 Interrupt cycle time (s): 0.665689
CPU 8 ISR highest execution time (µs): 5.981316
CPU 8 ISR total execution time (s): 0.015484
CPU 8 ISR count: 37772
CPU 8 DPC highest execution time (µs): 53.260764
CPU 8 DPC total execution time (s): 0.015524
CPU 8 DPC count: 4581
CPU 9 Interrupt cycle time (s): 0.398368
CPU 9 ISR highest execution time (µs): 3.025724
CPU 9 ISR total execution time (s): 0.000430
CPU 9 ISR count: 724
CPU 9 DPC highest execution time (µs): 29.485784
CPU 9 DPC total execution time (s): 0.000954
CPU 9 DPC count: 349
CPU 10 Interrupt cycle time (s): 0.684854
CPU 10 ISR highest execution time (µs): 5.350122
CPU 10 ISR total execution time (s): 0.005529
CPU 10 ISR count: 10885
CPU 10 DPC highest execution time (µs): 44.113458
CPU 10 DPC total execution time (s): 0.033849
CPU 10 DPC count: 5493
CPU 11 Interrupt cycle time (s): 0.492624
CPU 11 ISR highest execution time (µs): 2.895478
CPU 11 ISR total execution time (s): 0.005118
CPU 11 ISR count: 9573
CPU 11 DPC highest execution time (µs): 41.889250
CPU 11 DPC total execution time (s): 0.006736
CPU 11 DPC count: 959
<Moderator Note: Please do not post long log file output without using the "spoiler" tags>
