I recently replaced a battery in my c600, and took the existing battery out to use in my c640. In the c600, the battery would never charge more than 80% according to the led's on the battery itself.
When I discharged it and began charging it in my c640, I noticed that it would charge at a much higher rate than the standard battery, but after 5 or 6 minutes it would stop charging. Removing and re-installing pushes it up 4-5 % each time. Then I added a second (smaller) battery in the other compartment that was about 99% charged, and the first battery started charging in a much more regular fashion.
Anybody able to explain this behavior? Is it really OK to use the 5200mah battery instead of the 4460mah 66whr that appears to be standard?
Thanks,
Bill
Thanks,
Bill
