Thanks for the review, though it raises almost as many questions as it answers, for me.
The article said:
If you want NVMe on the evaluation board, use
The paragraph literally ends there. Did you mean to say "... board, use the Lite Carrier"?
The LattePanda Mu uses 4.9W at idle and 15.8W under stress.
How was this measured? What was the stress test and did you measure at the wall?
I have to wonder whether you used a CPU-only stress test, because the iGPU on my N97 board can use even more power than the 4 CPU cores. For me to max the power consumption, I need to simultaneously stress both the CPU cores
and the iGPU! Furthemore, I found that different GPU workloads use markedly different amounts of power, even when GPU utilization is nearly 100% in all cases.
The promotional materials for the LattePanda Mu claim that the board has a TDP of 35W, but even with our 19V, 90W LattePanda PSU and some unsubtle tweaks in the BIOS, we were unable to trigger power draws that high.
Did your tweaks possibly include raising the power limits of the SoC? I've had limited success by increasing PL1 and PL2. The main effect I've observed is simply that setting higher values prevents the CPU cores from throttling when there's a heavy GPU workload running at the same time.
Also, if the 35 W board power refers to the carrier board, then they must also be accounting for the maximum amount of power the peripherals use. On my N97 board, I've seen a CPU + GPU workload use up to 54 W at the wall, if I raise PL1/PL2 from their defaults. If I account for the PSU's supposed 89% efficiency, that translates into 48 W board power. Note that the N97 has a PL1 that's double that of the N100, although I think they both have a recommended PL2 of 25 W. Interestingly, my board has a default PL2 of 15 W, but then its heatsink really isn't very good.
Ubuntu 24.04, which we did try to install, but it crashed.
I installed Kubuntu 24.04 on my N97 board, mere days after it was released. The installation and subsequent usage has been flawless. Kubuntu is simply Ubuntu, but with KDE serving as the default desktop environment. They both use the same package repositories.
the extra power comes at a price. The $190 bundle of the Primer Carrier and Mu is the best option to get started with
I'd recommend people to consider the ODROID-H4. The base H4 includes the faster N97 CPU and sells for just $99. Unlike the LattePanda Mu, it lacks memory, but that's a plus because you can use a 32 GB or 48 GB SO-DIMM (as opposed to the Mu's meager 8 GB) and it accepts regular DDR5, which is lower-latency than the LPDDR5 used by the LattePanda Mu. Even if you add a $45 Crucial 16 GB DDR5-4800 SO-DIMM, you're still at just $144. Then, add a case and power supply for another $19.40, which brings you up to $163.40. Now, if you add a $37 Team Group MP33 M.2 2280 512GB PCIe 3.0 SSD, you have a fully-functional PC for just a hair over $200, and it also has double the RAM and is 200 MHz
faster than the Mu!
www.hardkernel.com
If you need even more power, you can step up to the
ODROID-H4 Ultra, for $220, and get 8 cores, a 33% bigger iGPU, and yet another 200 MHz single-core frequency limit (bringing us up to 3.8 GHz, or 400 MHz above the N100). Estimated system price: $320.
Note that while the ODROID-H4 boards aren't mini-ITX, you can buy a [url="https://www.hardkernel.com/shop/h4-mini-itx-kit/]mini-ITX adapter kit[/url] for only $15.
BTW, the N97 board I mentioned above isn't the H4, but rather a mini-ITX board made by a company called Jetway.
