LC-60LE644U problem when plugged in
jordanbuechler91
My sharp Aquos smart tv turns itself on a few seconds after i plug it in. It then shows the sharp logo, after that it goes black and responds to nothing. remote or buttons on tv do nothing
Did try to reset with holding the volume down and power button on tv, does nothing
also the netflix app stopped working before this started. i then got it to work by deleting and reapplying, then the tv went black and started the problem
I'm going to replace the t-con board. I found one for 10 dollars on ebay. The TV technician on justanswer.com said if it doesnt fix the problem it might be the FRC board. I will keep you posted on what fixes the problem or not.
Did you ever get it figured out. Was it the t con?
