Question LC-Power Gaming 988W with Coolermaster Hyper 212x
Then I'm led to believe they changed the side panel design and never updated it on their own website.
If you're lucky, you'll won't get a package with the old panel equipped.
Looking over the case's design, that front panel is terrible for airflow, and has no filtration - but the top panel does; one of the sides that doesn't need a filter, because it should be an exhaust.
I hope you don't plan on putting any high power parts in there...
It is different company with the same specs.Also the LC-Power Gaming 988B with the coolermaster cpu cooler
View: https://youtu.be/Dvd1nhF_iUA?t=1163
The case isn't the best as it should be but i like the design.
