LCD Monitor Connectivity
sureshmrao
My Desktop configuration is "Pentium 4 and 512 RAM". and its working fine. i have CRT monitor, but now i have planned to replace my old monitor with LCD monitor. will it be possible to connect LCD monitor to the above mentioned configuration?
Thanks in Advance Suresh MR
if your using onboard video ports look at the ports. some motherboard had vga and dvi ports. the dvi ports where white it color.
http://en.wikipedia.org/wiki/VGA_connector
http://en.wikipedia.org/wiki/Digital_Visual_Interface
if your motherboard does not have that port. look at the sales sheet of the monitor. some monitors have both inputs on the back. if yours does all you need is a vga cable. if the monitor is dvi or hdmi only there are a few cables and adaptors you can use.
vga vs dvi adapter
http://www.cablewholesale.com/products/dvi-products/dvi-to-vga-converters/product-10v4-05302bk.php?utm_source=GoogleShopping&utm_medium=organic&zmam=54972865&zmas=1&zmac=1&zmap=10V4-05302BK&gclid=COyv3Jr7yLsCFbFxOgod7DQAyQ
hdmi to vga cables.
vga vs dvi adapter
hdmi to vga cables.
