Lcd monitor flickers when I resize window
Jash
4
Hi,
I recently went to the store to check out 22 inch lcd monitors and I noticed the benq g2220 monitor, having a response time of 5 secs flickering when I resise the window, can you tell me if this is monitor fault or a graphics settings problem or anything else,
As the monitor has a native resolution of 1920 * 1080, do you think this is to high a resulution for this smaller size screen?
First I think you mean 5 milliseconds or (ms)
That's a pretty fast response time. I don't think that is a monitor issue but "flickering" isn't really a good enough description.
Is it the window itself or the whole screen?
Can you give a more detailed decription please?
dose the screen flicker when you scroll up and down in a web browser?
then try and re-installing/updating your graphics driver and make sure the cables are nice and snug.
it is 5 msecs, my bad sorry,
flickering means that it kind of looks like the screen refreshes and keeps on refreshing whenever I drag the mouse to resize the window
