Hey, hopefully this is the right place to post this
I'm having issues with my monitor and was hoping someone could confirm or contribute to my understand of the problem.
The monitor is a 24" Samsung LCD (2443bw) basically it only is able to display an image for a few seconds. For example, if i boot the desktop, it starts normal, about 2seconds later i get a black screen. It stays that way; if i turn off the monitor and turn it back on, it display what i should again for another 2-5seconds then the screen goes black.
This is a monitor problem, i tried plugging my xbox 360 into the monitors dvi slot and basically its the same situation. I see the 360 dashboard for a few seconds and then its gone. If i turn the monitor off and then turn it back on, i get the display for a few and its gone. The light on the monitor doesn't blink, it stays on as though everything is fine.
Without a device attached i get the normal monitor screensaver saying to check inputs.
Any ideas?
I've done some research and I've read several different things: such as capactior problems and inverter problems.
Cheers,
David
Any ideas?
Cheers,
David
