LCD Monitor with 1024x768 resolution?
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I was considering replacing my 19" Mitsubushi Diamondtron with a 17"
LCD type. But I've just learned that you should only use 'native
resolution'. So far all the 17" models I've seen have native
resolution of 1280x1024, which I have trouble reading comfortably.
Anyone able to recommend a 17" LCD with 1024x768 please, available in
UK? It will have to be compatible with my 4 year old PC, an AMD Athlon
XP1800+, 512MB with 64MB NVidia Geforce2 MX graphics card.
Terry, West Sussex, UK
G
Guest
Guest
In article <6v3l51d0lmke1kupp890rpckqc57atd1js@4ax.com>,
Go to http://www.newegg.com/app/manufact.asp?catalog=20&DEPA=0
This screen will help you narrow down your choices. Of course model
names can be different overseas and I'm not sure what "Max resolution"
means for an LCD.
I'd pick by size (17 inch) and dot potch.
a d y k e s @ p a n i x . c o m
Don't blame me. I voted for Gore.
Jerry
1,812
Go to your local computer store and view an LCD monitor while switching
between 'native' and what you want. It is not required that you use
'native', only recommended.
Also, LCDs may come with ONLY DVI (Digital) inputs as opposed to analog or
both so verify your video cards output.
Victorville, California
"Terry Pinnell" <terrypinDELETE@THESEdial.pipex.com> wrote in message
news:6v3l51d0lmke1kupp890rpckqc57atd1js@4ax.com...
G
Guest
Guest
On Mon, 11 Apr 2005 15:57:53 +0100, Terry Pinnell wrote:
> I was considering replacing my 19" Mitsubushi Diamondtron with a 17" LCD
> resolution'. So far all the 17" models I've seen have native resolution
We've purchased everything from a $7K b&w for CAT/EMI's to a cheap $300
LCD from the local computer place. Not one of them has been as clear/sharp
as the average CRT type monitor. Save yourself the money and get a average
priced ($250) CRT and you'll be happier than with the LCD.
spam999free@rrohio.com
remove 999 in order to email me
G
Guest
Guest
Thanks all.
Sandman
138
This is a good idea because buying an LCD without seeing the display
first would be a mistake.. CRT monitors can be counted on to be pretty much
adjustable over a wide range; LCD should be run at the native resolution
because otherwise the 'scaled' image is not very good. Every LCD panel has
some of its own characteristics; not all 19inch models look the same , for
example. So, like the man said, go to your local store and look at the ones
you like and compare. As for the readability of the text (if that's what you
are talking about) you can change type size in Windows XP and use Clear Type
from Microsoft which I would guess would make the text the way you like it..
After you have used an LCD, a good one, for a short time, you will not
go back to a regular monitor, trust me. Just don't buy a small screen (like
a 15 or 17) get the best one you can afford and at least a 19inch..
news:tuql51592alruvojej3afgrfpl8a254u5i@4ax.com...
or
> Thanks all.
