so this recently started about a month ago and i cant seem to fix it.
i have a Hyvision Megavision MV-220 monitor and its a couple of years old. It has started with this problem where the monitor turns on and the backlight is working for about 2-3 seconds and then the backlight doesnt work. i have let it sit for an hour and then i turned it back on i have now opened it up to see if any of the capacitors were blown(they arn't). the only solution i have to get it to turn on with the backlight is just random luck. its really become a pain because if i can replace the inverter board if thats the problem that i would be fine with that. if anyone knows where i can troubleshoot this or if anyone else knows waht i should do please do. Thanks -Mghynek
