It is not a marketing term, it's just like the minimum specs for games, it's what you need to get going while biggerrer will be betterrer.
You're absolutely right about what you need to get going, versus 'biggerer will be betterer'.
After what I've seen just tinkering, I seriously question whether 'biggerer will be betterer' is really worth the price, especially in the here and now. Of course, well-informed upgrades, and finding the right information when things are not working well, tend to help.
I'm generally about bang for the buck, but the last two years of my escapades have a been a prime example.
I am now sort of between systems. Try to keep a long story short, I was gifted a CyberPower in 2018. The box labeled "Utimate Gaming System" contained a CyberPower Onyx case with a 500W Channel Well PSU, R7 1700, AMD equivalent Cooler Master, MSI B450M Bazooka, 8GB DDR4-2133, MSI GT1030, and a 2TB HDD. Not terrible, but hardly what it was made out to be, and likely overpriced as well.
Between now and then, $500 in upgrades didn't turn out as planned. Mostly mysterious lagging. But I couldn't seem to find anyone that knew what was going on. 2022 was a bad time to buy hardware, but I'd had enough of the problems and didn't think I had enough horsepower.
This time, $2600 got me the Asus Tuf B550-PLUS with an R9 5900X, Scythe Mugen 5, 1TB SN570 M.2, 8TB WD Black, 32GB of Crucial Ballistsix DDR4-3200 (same previous SKU), Asus KO RTX3060ti-8-OC, with a Corsair RM850x in a Corsair 4000X RGB, cooled with six Corsair LL120s, and a Commander Core XT.
Fast? Oh, hell, yes. But this one had issues too. Chiefly a random blank screen on start, almost from the get-go. Reseating things was a temporary fix before it did it again. Someone suggested a memory training issue when I homed in on it being every 8-12 boot cycles. Since memtest86 had shown nothing, I RMA'd the board.
A bad CPU was also possible, so I built a temporary machine / test bed for the other components with an ASRock B450M-HDV and a used 3600X ($175 total). It lagged badly with one of these DIMMs installed. The other duplicated my issue. You could have heard me cussing in the next county. However, a kit from its QVL cured its ills. I also noticed very little difference in performance (apart from total CPU load) from the 5900X.
When returned, Asus noted my board as "could not duplicate issue". A Patriot kit from the Asus board's QVL cured its ills as well -- A YEAR AFTER I BUILT IT.
I upgraded to a Fractal Pop Air XL, ($109), and finished out the 3600X in the 4000X for resale with an M.2 ($40), a GTX1650 ($210) and Corsair CX650F ($70). Thought I could at least get my money back out of it with mostly new parts, but anyone here knows that building PCs for profit almost never works out.
Turns out the previous 1700 rig's memory wasn't on its board's QVL either. It now runs perfectly with some HyperX Fury DDR4-2133 ($50 on eBay) from its QVL. So what's my point?
Through all this, I learned that Ryzens and supporting boards are apparently quite picky about RAM, something that quite a few people have argued with me about on other forums. I've also learned that persistent annoying random video recording glitches with OBS Studio were solved using FLV format with OBS Studio, which I then edited and exported to MP4 / M4A. You could have heard me cussing in the next county when I figured that one out, too.
The 3600X is now a web / media NAS box ($150 case with another $150 in adapters), using the Tuf 1650S for encoding / transcoding, so it can still do light gaming. While the RTX3060ti is a better card that brings out the eye candy in some games I play, I wonder, was it really worth $850? I've even considered selling the 5900X rig.
Had I known then what I know now, or been able to find people with the right answers, my best bet would have been to shell out $2000 to swap the B450M / 1700 to a better case with a big cooler, PSU, SSD, RAM more to its liking, an RTX3080ti, overclocked the 1700, and it would have performed just as well, if not better, for about half to two-thirds of what I've wound up spending.
I mean, yeah, don't get me wrong, it's cool that the 5900X boosts to 5.00-5.025 at times, and ATS is awesome at 2K with high settings. I can also stage 14-28 vehicles chasing me on high detail at 2K in BeamNG, something the GTX1650 couldn't touch.
But being disabled on a fixed income now, with what I now know are autistic traits that make what others consider fairly innocuous issues 300X more frustrating to me, I really couldn't afford the headache or expense of the twists and turns I've had. Unfortunately, the last time I had someone build a machine for me, it did not go well.
While my 275mm KO card won't fit the 2U NAS case, an EVGA RTX3060ti XC will, and I can get one for $300 right now. I've been told my 5900X is worth $1000-$1500, and I could use the money.
But then again, a 3080 / 3080i / 3090 is really overkill for anyone who isn't doing CAD / CGI work. I've seen ATS played on a 3090, and there really isn't much difference from my 3060ti.
So, yeah, 'biggerer' isn't always 'betterer'.
