leak watercooling help
Mr Lorgy
Had a leak with my watercooling setup. The soundcard got a few drops on it. I had leak tested the system for over 24 houres, but got unlucky. Heared loud crackling from headset otherwise everything was normal. Wondering now how bad the damage could be. Here is a link of the soundcard http://imgur.com/WKoBkMy
If you leak tested for 24 hours, either you didn't leak test well or you did something else, causing the leak. You would have seen this during leak testing.
Where did the leak originate? What does your loop consist of? Do you have photos of the loop and more info?
Remove the card and completely dry. Brush the gunk from the card and reinstall it...see if it works. You might get lucky.
