LED controller cable splitter and fan cable power
ryanlaxman
58
I need to split the two pin female case LED controller cable. How do I do this/what cord/what connector type?
Also, I have a case that has a 200mm top or 2 120mm on top. It came with a split cable for the top fan/s. Only the 200 was plugged in when I got it. Will there be enough power if I plug in the back 140mm fan in the splitter with the 200mm? Thanks!
BTW just got the case and am getting the majority of my parts for xmas.
Thanks!
Well where you want to plug that 2Pin LED ?
Yes you could plug it in the 140MM fan :)
Im using it right now with my 2 120MM fans. ( Both plugged to 1 pin)
so it really has enough wattage for a 200 and a 140
cool :) thanks
and my friend is trying to split that 2 pin, the reason escapes me but i think he has another fan he wants to integrate into the LED controller and he still wants it to be plugged into one of the headers on his mobo
