I have a Cooler Master Stormtrooper and I replaced the large top fan with two 140 mm blue LED fans. I like the look they provide but when the fans are on low speed (which is most of the time) there is a strobe like flashing effect caused by the fan spinning slowly above the LED underside of the fan blades. It's not really noticeable with the fans at higher speeds, and they would be fine if I had them set up as intakes instead of exhausts since the light from the LED would not be obstructed by the fan blades. My question is are there fans with the LED's on the opposite (exhaust) side of the fan?
