[SOLVED] LED lights on fans doesn't glow too much
anonymous890
219
4
4,695
Motherboard MSI z97
I have 4 fans connected through 4 pin molex then 1 is connected to the system header fan. The LED lights on fans doesn't glow much, what is happening?
I had the same fans on my asus p8h61-m le, same config yet it glows brighter.
You will need to mention the make and model of your board. At the moment, it looks like you own an MSI board that is equipped with a Z97 chipset. Mention the make and model of the fans and how they are connected(off a splitter)?
Better yet, list your specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
