Led lights on front of computer wont turn on
cosmicblue10
Hello, I have LED lights on the front of my computer. They change color or can set to stay one color. They were working fine until I pressed the button to change the color from green to blue and it changed then went off and won't come back on. Can they be fixed and if so how?
have you tried pressing said button to change it back to the color that worked?
perhaps either you turned off the lights, there is a problem (short?) within the blue segment or the led panel burned out. led's don't typically burn out quick so i'm thinking either the unit is off or theres a circuit problem. pop the front cover off and look if pressing the button doesnt help.
Thanks ssddx for the suggestion. I have tried pressing the button and nothing happens. You may be right about there being a circuit problem I will try to figure out how to work on that. :)
