Led Lights! With No Cables?
SomeRandyScrub
20
Hello there!
So, I am pretty excited to build my first PC, i am done and set with planning out the components but there is just one problem... Aesthetics... The Led Strips, The RGB, The Colours!
So, my question is: How do youtubers / PC builders light there PC up using the led strips that they bought such as from cable mod : https://cablemod.com/product/cablemod-widebeam-magnetic-rgb-led-kit-30cm/
or from amazon: https://www.amazon.com/SUPERNIGHT-Changing-Flexible-Remote-Control/dp/B00BP4DUMU/ref=sr_1_1?ie=UTF8&qid=1495989622&sr=8-1-spons&keywords=rgb+led&psc=1
Without any cables that go out of the case and get plugged into an outlet.... And they control it all with a controller, so do these led strips contain a battery that lasts forever or do the cables from the strips connect to something inside the case, or is it all just an illusion and the cables actually get routed outside the case and get plugged into to a power outlet. The case that i am getting is the S340 Elite ..... Please help me since RGB IS LOVE, RGB IS LIFE
Thank You Very Much In Advance,
and i hope u all have a wonderful day
