Question LED Lights
kiwis
38
I have a Aorus B450 Pro WIFI board (manual below) and a Phantek P360X case. (manual also below)
I'm not sure how to plug in the front LED lights (plugs on left of image here).
Any help would be appreciated.
https://www.tweaktown.com/reviews/9184/phanteks-eclipse-p360x-mid-tower-chassis-review/index5.html
http://www.phanteks.com/assets/manuals/PH-EC360X.pdf
http://download.gigabyte.us/FileList/Manual/mb_manual_b450-aorus-pro-wifi_1001_e.pdf
Tweaktown article said: "The front panel cables are as follows (left to right):
- ARGB 3-pin output cable (3-pin standard & 3-pin specialized header)
- SATA power lead for RGB control
- HD Audio connector
- USB 3.2 Gen 1, 20-pin connector
- Power Switch connector
- 3-pin ARGB sync connector (to sync with the motherboard)"
Don't plug the 3 pin output cable into anything unless you want to sync an RGB strip to the front panel
Plug the sata power into the appropriate cable from your PSU
Plug HD Audio into the motherboard where it should say "HD Audio". Header is shown in motherboard manual on the bottom left of the motherboard.
Plug the USB 3.2 Gen 1 connector into the motherboard. Header is shown in the motherboard manual on the bottom right, second from the right.
Plug the Power Switch connector into the motherboard. Header is shown in the manual on the bottom right corner, and the manual should also tell you which two pins to plug it into.
Plug the 3 pin ARGB connector (which is for the LEDs) into the motherboard. The headers for this are listed as D_LED1 and D_LED2, positioned at bottom middle and top right, respectively.
Page 11: Location 9 & 10.
These are pins and the plug has pins also.
Is that normal?
