LED power button not working
helloineedhelplol
18
Hello!
My entho pro m case has an LED button but I cannot seem to get it to work. I have a spare cable that says 12V input 416 but as far as my research has gone i need to connect it to a hub which i didnt get with the case. And my front fans that are supposed to light up also came with a to short cable to reach the led header. I dont know what to do.
I am thankful for all asnwers😀
Hi!
I have the enthoo pro, which I recently bought. The fan hub on the back does have a cable that connects the hub to 12v power (SATA connecter) but this is nothing to do with the power LED, I assume that's the cable you are talking about. The power LED to motherboard connector has a polarity on it, are you sure it is the right way round?
Here's a picture of the motherboard connector: https://linustechtips.com/main/uploads/monthly_2017_04/58fb969e9d469_Esquemacables.PNG.ab5c4d7b1681db480703cdf9a31d812d.PNG
I hope that helps!
Is this a thing?
Latest posts
