Hello members of Tom's Hardware.
Not sure who has experience with LED modifications here, but I am modifying a Chinese LED projector to work on my motorcycle as the stock halogen reflectors are very weak.
Well, the LED projector has a heat sink mounted fan that sits right in the area that retro fitters typically mount to. I am wondering if I can just remove the fan and get away with leaving no fan on the headlight. This headlight housing is vented through the bulb covers.
Here is the product. http://www.autokilight.com/product/60444928902-803014594/Autoki_2016_New_3_0inch_LED_Module_High_low_beam_Projector_lens_light.html
Here is the method I am using to mount the headlight. https://www.youtube.com/watch?v=Y4Fa2ypV7GA&ab_channel=TheRetrofitSourceInc
If I can't just remove the fan, can I mount a fan somewhere in the headlight housing that isn't on the projector lens directly? I feel like you all know cooling of LEDs very well compared to an automotive forum.
Thanks, feel free to leave your tips or comments
. i have also asked on a few other forums, so when I find the solution I will update you here.
