Led/Rgb Fans on H81M mobo
nith95
Commendable
Feb 6, 2017
101
Hello there, i have an h81m-d2v mobo , there is no RGB header. I want to place Led or RGB Fans (and an RGB magnetic stripe), but im not sure i can do it.
What can i do or purchase in order to make this possible? Are the LED fans working with this one? molex to 3pin
Thank you for your time!
I had this one too. The kit will come with all the cables you need. Power it with sata power cable (from the PSU), and connect it to MB with USB2.0 cable. And connect the fans or stripe to the rgb controller. Keep in mind you can connect only 4 devices into that rgb controller, if you have more then 4, you need other one.
For more info, check and download the manual from CM. http://www.coolermaster.com/cooling/case-fan/masterfan-pro-120-af-rgb-3in1-with-controller/
