I was thinking about putting some RBG LED strips in my case. I've seen a bunch of them on Amazon but most of them only contain 2 strips and are, at the longest, 20" long. The longer RGB Strips are 16.5' but do not have a PC compatible power connector but one is available but it must plug into a wall outlet. So I was wondering if the two items below would work together. I'm not really sure about universal compatibility with LED strips. Let me know what ya'll think?
I was thinking about using this to power the strip:
https://www.amazon.com/dp/B01AZ4XX0E/ref=cm_sw_r_sms_awdb_yQIcAbVCMN2MQ
Ans I was hoping this long strip would be compatible with the item above:
https://www.amazon.com/dp/B006LW2NJM/ref=cm_sw_r_sms_awdb_aPIcAbMCCSRXM
