I put together a new build recently, and for some reason, now the ceiling lights in the room flicker consistently when the PC is NOT under load. The below are my core components:
CPU: Intel 13700K
GPU: MSI 4090 Suprim
Mobo: ASUS Z790 ROG STRIX
PSU: MSI MEG Ai1300P
No crazy extenders or aftermarket cables; basically all stock.
The issue started as soon as Windows setup booted off a boot disk (even before the install started). The lights in the room will flicker almost constantly when the computer is sitting at desktop with no programs running or when it turns the screen off (not hibernation, just display turned off after 5min). The flickering will instantly stop when I wake the screen. If flickering at desktop, just running a YouTube video or something similar is enough to make the flickering stop. Absolutely zero issue when under load/gaming.
At first I thought the wattage was too high for the circuit in the room, so I plugged the computer into one of those power analyzers that plug into the wall. MSI also has software that reports how much the PSU is pulling. Both the software and the power analyzer agreed I'm pulling like 100 - 200 watts under normal use (yes I'm aware the PSU is total overkill, I just really wanted ATX 3.0 and that is what was available). Under load I haven't gone over about 400w, so doesn't seem like I'm drawing too much power out of the wall. Even if that was the case, I'm having issues when the PC isn't under load, and no problems when it is.
Anyone experience anything like this?
CPU: Intel 13700K
