Greetings everyone,
Now I know similar question has been asked multiples time before, but I am still not certain. I have a RM 650X PSU and am wanting to install some LED strips (12v) with a controller to change it accordingly. I am thinking of buying this LED strip with controller ( http://www.miniinthebox.com/5m-300x3528-smd-rgb-led-strip-light-with-44key-remote-controller-dc12v_p2256327.html ) and connect it with this adapter (https://nl.aliexpress.com/store/product/Power-D-port-Male-to-DC5-5mm-2-5mm-female-converter-adapter-power-cable-made-of/1087029_1705486609.html?detailNewVersion=&categoryId=70806) to my PSU. It says this adapter handles 12v and it also tells me the controller requires 12 volts. Am I overlooking something or should this work just fine?
I am uncertain because I've looked at others adapters (like the one from the Hue+) and saw the location etc.. of the wires coming from the molex are the same, but with other adapters they aren't. I am not sure if wires will not match correctly and the last thing I want is a dead computer.
Thanks in advance for the help
