LED Strip Help?
lightning45
Commendable
Mar 3, 2016
17
Hey guys,
I'm currently planning a gaming build. The theme will be black and white and I want a white led strip for it. I was planning on going with the cablemod widebeam ones but the problem is I want the availability to turn off the lighting when I want. Are there any good led strips that have this functionality or anything I could do to achieve this with the cablemods? Any help is greatly appreciated.
Hey mate,
I strongly recommend the NZXT Hue+ RGB LED Lighting kit becuase of all the customisation's you can achieve with this unit. NOTE: It will need a 2.5" drive slot or 3.5" slot for the controller (there is software to download for it) a spare usb 2.0 header on the motherboard and a spare molex connecter.
I recommend watching this video to get a full understanding of what the product is and what it does.
https://www.youtube.com/watch?v=dYnULV8aC7E video does go for 30 mins.
Best regards Joy0003
Hey mate,
Thank you, I will definitely give it a look. This can be used for white lighting effects if I want right? In all honesty, I would be perfectly fine with only white, but this seems like the best solution, and with an off and on switch.
No worries mate,
so with the NZXT Hue+ it gives you the functionality of turning the led strips on and off and with the addition of rbg lighting as well
The software you download is the controller for the led light strips.
Alright perfect that's just what I want. Thank you.
