Led Strip Wiring Questions. Please Help!
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Hi!
I have 4 strips of Bitfenix Alchemy LED strips (2 x 30 cm, and 2 x 12 cm) to put in Corsair Air 240.
1) My question is, if I were to put the 2 long ones in the top and bottom, and the two short ones on the front and back, what would be the cleanest way to plug them in?
2) I am a a noob to LEDing computers, so what connection would I use?
3) Would they just plug in the power supply or motherboard? My motherboard is the MSI H97 G43.
Thank you very much!
They should just plug into a standard 4 pin Molex connector coming from the power supply.
You might need to use a Y-adapter if you are short on internal power connections from the PSU.
Plus maybe some other connector adapter to accommodate the available physical connectors. You will need to look inside the case to verify.
