led strips 12v
starphilosophy
49
how do i power these i have 12 v lked strip that has positive and negetive leads. i was thinking a 12 volt battery or is there a way i can solder a 4 pin connecter. molex is kinda out of the question right now
Do you have a pic of you strip and connectors?
All 12v led strips I have came with red and black wires already on them. Just connect Red to + and Black to -
Do you want to power it from your pc? But you don't have a connector?
Just connect the + to the yellow of any power supply lead and the - to a black one. Cover well with wire insulation tape. If either one of those touches anything else in your PC, it can quite easily destroy it so be careful to insulate well.
yes thats how my led are can you go into more detail about powering them through powersupply mines modular evga 750 gq
Check this out:
http://superuser.com/questions/774920/led-case-lighting-installation
It sounds like you don't have a spare connector like he does though.
What I did is pull a black and yellow wire out of the molex and push my black and red led wires into them.
http://images.ncix.com/forumimages/DD73B0B5-1171-102A-E6D08112CB35E05D.jpg
It's obviously better to solder the wires together but this makes it permanent. Maybe just go to a pc store and buy a splitter, then you can cut the wires on the splitter and do a nice job that allows you to remove and reconnect the leds later.
Just be careful though - if your led strips aren't of the waterproof variety, then you have exposed 12v wires along them and if anything touches that it will be trouble.
