netsuJ Commendable Sep 9, 2016 76 0 1,630 Oct 4, 2016 #1 Is there anyway to connect my led strips to my power supply? Currently I just have my led strips connect to a outlet then I fed it through my case. IMG of my PC: https://postimg.org/image/scpabgfbn/
Solution Multipack Oct 4, 2016 Depends what PSU you have, and what LED strips, but most PC LED's use 4 pin molex from the PSU
Multipack Honorable Sep 5, 2016 4,283 3 9,960 Oct 4, 2016 Solution #2 Depends what PSU you have, and what LED strips, but most PC LED's use 4 pin molex from the PSU Upvote 0 Downvote Solution
Zerk2012 Titan Ambassador Oct 6, 2014 22,422 2,457 104,240 Oct 4, 2016 #3 http://cdn.pcpartpicker.com/static/forever/images/userbuild/159545.c22a13a78d393de8ce80007eb0c6f4df.d72cb0143afd55aadf61630f76338ead.1600.jpg I have mine hooked up to 2 switches mounted in a 5.25 inch front case bay and connected to the PSU. What you can do depends on the lights you have. If their 12 volt then yes on the power supply. Upvote 0 Downvote
