LED turns off as i power up
Hitman_Wolverine
Commendable
Jan 30, 2017
My toshiba L55t was working well, after a while i try turning it on, no lights whats so ever,
i plugged charger, no LED indicator is on, wont power up, I tried removing the battery and holding on button for a while then plugged the charger, the white(full battery) was on, but when i press the power button, the LED is off.
While the LED was on, before i pressed the on button, i put in the battery and the LED changes from white to orange but then again when powered the light disappears, Plz i am desperate for support,
Try the following and see if it will turn on...
1. First make sure the device has been charged.
2. Unplug your charger cord.
3. Remove the battery.
4. Press and hold the "Power" button for 30 seconds.
5. Now plug back in the power/charger cord.
6. Now put the battery back in.
If this doesn't help, then test the power cord to see if it is good. Either try your cord in another device, or try another devices cord in your laptop.
Should that not be the problem, then check the battery to see if it needs replacing.
Thanks for the replay, i tried that multiple times, i was afraid the motherboard was damaged so i checked for continuity of circuit via multimeter throughout,all good so i ruled it out, any technical stuff i can do to remedy?
ps : charger works, 18-19V output by multimeter
