Question LED_CPU with RGB fans on Gigabyte B450M DS3H
Nov 19, 2020
Hello,
My current MOBO is as mentioned in the title, a Gigabyte B450M DS3H. I have purchased the 3 pack of Cooler Master MF120R 120mm ARGB fans and a splitter (ID-Cooling HA-02) with I will use as a PWM hub only. My MOBO has no 3 pin RGB header as the problem with the person on the ticket I mentioned. Instead it has that LED-CPU header which they cannot fit into. You mentioned that you might have to buy some kind of attachment to fix this but first:
  1. Will this header serve the same purpose as a normal RGB fan controller header when a splitter is attached
  2. If so which splitter do you recommend purchasing?
Thank you very much for your time.
