Length of SATA cable for a full tower
CompUser08
Commendable
Jan 20, 2017
11
Hello. I am almost finished gathering all of the parts that I need before I do the assembly of my PC.
I was wondering how long or what would the perfect/best length of cable for a full tower case?
My case is Fractual Design XL R2.
Thanks!
Uhmm, consoles I mean PS4 or Xbox One. The Nintendo systems were never really considered because they are way underpowered in comparison to PS4/PC/X1. That said, as you need just a single screen, and don't want to muss alot with Power Supply demands, risk rewiring / shorting / breaking something, as I suggested, the easiest is just a i5 Based PC, buy a 1050Ti (doesn't require a power upgrade) unscrew case, install, and your able to game as your asking for though NOT Game's MAXIMUM GRAPHICS.
For that you need a Gamer's Rig, which then your looking over $700 and upwards. Again you can go for a i5 Based one, there is prebuilts, and I would suggest a 1060 to cut down price, but normally people investing in 1080s, skipping the 1070. That...
To paraphrase Lincoln, the should be long enough to reach the drive. :)
SATA spec is the cables should be between 30-100 cm. Shorter than 30 cm (12 inches) and you may have interference problems with internal reflections. Longer 1 meter (40 inches) and you may have problems with signal degradation. PCB traces from the motherboard's SATA controller to the socket, and on the drive have to be included in this length. So 30-36 inches is a safer maximum.
Most people like to use cables which are long enough to reach from the SATA ports to the drives, with the table tucked onto and cable tied to the edges of the frame, but no longer. That way they're both out of the way and do not impair airflow, and you don't have excess cable taking up space.
Having just swapped my case out I can attest to that it depends how your case is designed.
Original case https://www.amazon.com/gp/product/B008ANFQ8U/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
New case https://www.amazon.com/gp/product/B01JMVLBUA/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
My old case had hang down cabling, because the mobo hung along one side, and while I could tie down best I could still left (as said above) pretty ugly airflow. The new case puts the board horizontal and then feeds the wires below it, which is incredibly smart IMHO. So now I can wire no issue, max airflow across the BOARD (it isn't just your CPU and GPU you need to cool) and still have easy access to stuff
CompUser08
Commendable
Jan 20, 2017
11
Sorry for being late. I plan on using possibly all 8 SATA connectors. I forgot that SATA cables do come with the motherboard. Thanks.
One more question. I have 32GB RAM (2 x 16gb) and I was wondering if this is enough for chatting online, web browsing, listening to music, watching movies and tv shows, playing CoD: MW3, CoD: BO2, and GTA V? If possible, I was planning on recording/capturing from a cable box, editing the video, and encoding/converting video as well.
I probably won't be recording, editing video any time soon but if the need arises. Oh, and I plan on encoding/converting video in the background while playing those pc games, listed above. while waiting for the video encode/conversion to complete. in the foreground.
I cannot decide between staying with 32GB or going all the way to 128GB. I am not computer smart. Please help me. Thanks.
Okay tossing "bigger numbers" at things in computers doesn't mean you get the result you want. What your asking to do is a big problem and NOT FEASIBLE.
It isn't "I need more RAM" but there is alot of parts here we are talking about that do alot of different things for different usages so let's break down a bit here.
1) You don't need 8 Drives, in fact there is really no need for it unless your running RAID arrays (which is a different discussion) to have multiple drive failover and 'hot swappable' drives.
2) COD MW3 no one has played in years and doesn't take any real 'hardware' to play with the current gen systems. BO2, does take some hardware and GTA V of course needs a solid base - BUT it all depends HOW you intend to play these games.
Are these / other titles going to be played on a single screen?
Are you expecting a particular resolution? Graphics detail level?
3) If you need a "video encoding and conversion" AND you want to play video games, then you need TWO systems, not one. Video editing is CPU intensive, and yes the MORE memory you have to that task the better, but really you also need high speed drives, most take advantage of a SSD as the 'work / OS' drive then have a second or third (depending on how much production they plan to do before archiving the work to the NAS) to 'move' the work to when done to store for the time period to use that video then archive all the videos.
4) For the titles you mentioned, the "gaming system" you can even just stick to a Console if you wished, and yes you can capture to the Digital Editing PC from there the cable box, whatever with a simple Capture Card. Otherwise a simple "Walmart" i5 and toss in a 1050 Ti (so no mussing with the power supply) and you can game all the current titles or ancient ones like you mentioned for a single screen 1080P usually Med / high Graphic detail for 40-50FPS performance. But (points up) depends alot what you 'expecting to play'.
5) "I am not computer smart." - OKAY?!? Your tossing out stuff like you 'know' something, that is a start but what your 'tossing' is basically yourself with a 100lbs weights tied to you into the DEEP computer smart ocean area. This is sort of stuff your asking to do, is not a "appliance" you can just buy and "figure out" over time, alot of this is learning the basics first so you don't blow wasted money (hundreds of dollars) in mistakes and errors. If you really don't know ANY of what I just replied back with above, then STOP for a second. Go to the local bookstore and get the Idiot's Guide (they are awesome series) to CompTIA A+ Certification. The A+ certification covers EVERTHING A-Z on computers, and once you know that 'basics' then you really can start making better judgment on what you need and how to achieve it, because YOUR ON YOUR OWN WHEN WORKING ON PCs. YOU ARE EXPECTED TO SOLO FIX AND DEAL WITH ALL YOUR OWN ISSUES (WARNING Will Robinson! Warning! - LOL). There is no simple step by step, or ABC click here do this done solutions ALOT of it is methodical, logical step by step process of elimination.
I hope this clarifies things more.
CompUser08
Commendable
Jan 20, 2017
11
1. I do need st least one or two hard drives for storage/archive of files. No need for RAID array.
2. Yes, on a single screen. No particular resoultion except for the highest resoultion that the game supports. Graphics detail level will be set to the game's maximum.
3. I won't be editing video, well, not now at least. Maybe in the future. I won't be running both programs at the smae time but rather one at a time.
4. I have consoles but they use batteries and the batteries will fail over time. I decided on PC but I had to make compromises such as losing the ability to play offline unlike I can do on console.
5. I will take note.
For that you need a Gamer's Rig, which then your looking over $700 and upwards. Again you can go for a i5 Based one, there is prebuilts, and I would suggest a 1060 to cut down price, but normally people investing in 1080s, skipping the 1070. That means a serious power supply (over 650W) and installation.
There is several magazines you can check for, or shop online, with those base items in them, and you can shop from there. Most will also (as Gamer's Rigs) be SSD on C drive for the Base OS and then 1+TB for D drive for the game installations since they take up the most. If you get a prebuilt it will cost you near $1000+ for those systems, but they are all warrantied, etc. to work 'right out of the box'.
If you want to build it yourself, you can get the same parts cheaper, best shopping tool is www.pcpartpicker.com but YOUR ON YOUR OWN. If you frag something they won't let you "exchange" for another, you have to pay out of pocket for a whole new part. Further you need to breadboard it slowly before actually even getting to Windows installation to make sure the hardware all working to at least POST. Again this is all covered in CompTIA A+ and some nice videos on Egghead.com There isn't much short cut or reach out, so it is high risk for noobs to building, but you can learn alot more and feel accomplished you built it yourself, as well as shave a few hundred here or there sometimes.
