LENOVO G40-45 wont boot and fan not working
julian_mustofa
40
Hi everyone
My laptop won’t boot and screen didnt show anything
When i turn it on,
-Hdd indicator work
-Carging indicator work
-camera led work
But
-fan doesnt work (only work 1second and stopped)
-screen didnt show anything even the lenovo logo and cant enter bios
Around 30second after i turn it on, it like restarted itself, fan spinning 1second again and stopped, it seems like they trying to boot
Then i try to reset bios by holding power button 20second, and it work, it can boot to windows, but after i turn it off. It wont boot again
I try resetting bios for 2nd attemps, but it doesnt work right now. I try and try again. Still doesnt work
Then i try
-clean the ram
-Remove hdd
It still doesnt help
Is this because corrupt bios?
It may well be hardware rather than software. Try the following and see if you get any screens...
Also take note of if the lights stay on or if they go off like the fan sounds. If they stay on, then the device isn't restarting.
1. Turn the laptop off (not sleep or hibernate but off).
2. Connect an external monitor to the laptop.
3. Turn on the external monitor.
4. Turn on the laptop.
NOTE: You may have to press an "external monitor" button. Could be the f4 button or a button with two monitors on it, for the external monitor to work.
If you can see fine on the external monitor, then your attached display, or the ribbon cable that connects it, are your problem.
If you can't see on the external monitor at all, or the problem occurs on the external monitor as well, then it is probably the graphics card/GPU that is the problem, which may require the motherboard be replaced.
You may also want to try hitting CTRL + SHIFT + WIN + B to try and reset your graphics driver as another possible fix.
Hdd light is indicating that is restarted, also the light on camera to, fan spinning again but only 1second and stopped
But i think its not the lcd screen, because when i reseting bios at the first time, it succesfully boot up to windows, and the screen working with nothing issue
But it wont boot again after i turn my laptop off
