Lenovo G500 Intel-AC 3160 WiFi card upgrade
nol2
So I wanted to upgrade my WiFi card in my G500. I read, first I need to delete the whitelist from my BIOS to make it happen. It happened, it has been deleted, the BIOS has been upgraded as well. But I cannot make it work in any possible way, I installed every driver that has been out for AC 3160. It does not show up in device manager either. Can someone help me, what else should I try?
I included some pictures, what should I enable and what should not.
Picture 1
Picture 2
Picture 3
Thank you in advance.
After many different possible solution, which I found on the internet, I came to a conclusion it will not work properly. However there was one time I was able to make it work, I had great download speed, but weak upload and even the system behaved strangely, it was absolutely unreliable. So I stuck with the previous WiFi card. For me, the case is closed.
